on my supercharged 94 Z-28 i want to change the suspension ive been looking at the bilstein eibach package from slp, but i dont want my car to low or to stiff , i do like to drag , but i also want improved cornering. i have upgraded brakes and when i brake hard my air scoop drags on the ground so it deff. needs to be stiffer . any imput? i would also like to know if anyone has had any prob. with camber ajust. after lowering . thankyou for your help -Kevin
suspension ?
suspension ?
1994 Z28 stage 2 intercooled procharger, P-1sc, 6lb pully,42lbfuel injectors,255intank pump,1 3/4headers,highflow cat, borla ajust. cat back,chrome moly LCA,chrome moly ajust. panhard bar, Kenny Brownweld-in subframe conectors, built trans. kevlar lined 2600 stall, kevlar clutches, hardend parts,,built rearend; moser axles, eaton posi, richmond 3.42 gears, rare ROH ZR6 17* 9.5 wheels, custom computer tune with laptop and LT1edit , 380rwhp 395rwtq , 60' 1.71, 1/8th 8.00,1/412.60@109mphTags: None
your gonna need the camber plates and im pretty sure in the rear u will need the LCA relocation brackets, adjustable panhand rod. im sure ppl who have lowered cars will chime in2009 Honda Civic EX- the daily beater
any idea where to get camber plates?1994 Z28 stage 2 intercooled procharger, P-1sc, 6lb pully,42lbfuel injectors,255intank pump,1 3/4headers,highflow cat, borla ajust. cat back,chrome moly LCA,chrome moly ajust. panhard bar, Kenny Brownweld-in subframe conectors, built trans. kevlar lined 2600 stall, kevlar clutches, hardend parts,,built rearend; moser axles, eaton posi, richmond 3.42 gears, rare ROH ZR6 17* 9.5 wheels, custom computer tune with laptop and LT1edit , 380rwhp 395rwtq , 60' 1.71, 1/8th 8.00,1/412.60@109mph
I've never heard of a camber plate for a 4th gen. I know the third gens with the struts could benefit from a camber plate to move the top strut mount forward and back to optimize alignment. But since 4th gens don't have struts this doesn't apply.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
so what do i do ?1994 Z28 stage 2 intercooled procharger, P-1sc, 6lb pully,42lbfuel injectors,255intank pump,1 3/4headers,highflow cat, borla ajust. cat back,chrome moly LCA,chrome moly ajust. panhard bar, Kenny Brownweld-in subframe conectors, built trans. kevlar lined 2600 stall, kevlar clutches, hardend parts,,built rearend; moser axles, eaton posi, richmond 3.42 gears, rare ROH ZR6 17* 9.5 wheels, custom computer tune with laptop and LT1edit , 380rwhp 395rwtq , 60' 1.71, 1/8th 8.00,1/412.60@109mph
You can get an adjustable upper A-arm....
This company also makes a camber kit. http://www.drivewire.com/performance...amberkits.html
If you want to get rid of the body roll get bigger sway bars.John
97RS "Arrest me red" - LETSCEM - under the knife
02WS.6/TA #4024 "Wash me again black" RDOZREL - Hotchkis STB, MTI lid, BMR SFC's, BMR SB's, SB Brake Lines, SureStop rotors, Carbotech pads.
99 Bravada
thank you . any input on shocks ,stuts, an springs ?1994 Z28 stage 2 intercooled procharger, P-1sc, 6lb pully,42lbfuel injectors,255intank pump,1 3/4headers,highflow cat, borla ajust. cat back,chrome moly LCA,chrome moly ajust. panhard bar, Kenny Brownweld-in subframe conectors, built trans. kevlar lined 2600 stall, kevlar clutches, hardend parts,,built rearend; moser axles, eaton posi, richmond 3.42 gears, rare ROH ZR6 17* 9.5 wheels, custom computer tune with laptop and LT1edit , 380rwhp 395rwtq , 60' 1.71, 1/8th 8.00,1/412.60@109mph
You shouldn't need anything in the way of camber plates (they are for cars with "struts".... 4th Gens are unequal length A-arms), or adjustable upper A-arms in the front. I dropped the front end 1.8" and they had no trouble achieving the recommended alignment for lowered cars (-1deg camber, +4deg caster, 0.1 toe) with the stock adjustment range provided by the bolts and slotted holes on the front and rear of the lower A-arms. Some people prefer to add a bump-steer kit if you drop it more than 1.5".
The LCA relocations brackets would be a good addition for the back end.Fred
How serious do you want to go with the suspension? Drag or road race/autox?
Fred(Injuneer) will point you in the right direction for a good drag setup. There are a few others here that have that knowledge also.
A cheap road race/autox adjustable shock would be KYB AGX($400 a set). KYB is single adjustable. Koni is my pick. I have a set yet to be installed. Koni has single and double adjustable shocks. I got double adjustable shocks.
Springs....how stiff do you want the ride to be?? I know people that run up to 900# rates(racing only). He does not drive this car on the street. The higher the rate the stiffer the ride. Still trying to figure out what spring rate I want to use with my Koni's.
Check this website for price info.
http://www.shox.com
Also check this website out for some good info.
http://www.musclecar-usa.com/carsetup.shtmlJohn
99 Bravada
Here is the best consolidated information on springs I have ever seen for a 4th gen. You can compare the stock spring rate with a bunch of aftermarket springs to decide which is best for you. I'm going with the BMRs someday. That will be after I get the MP3 player for the car.
http://www.f-body.com/forum/showthread.php?t=87822002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
well like i said i want a big improvment over stock but i dont want my car to be too low and i dont want the ride to SUCK eather , that why i ask about the kit from slp i here good things about that what are your opinions, i do like to take my car to the track for a good beating but i also like to hammer arround corners and drifting them too. THANKYOU FOR YOUR HELP -Kevin1994 Z28 stage 2 intercooled procharger, P-1sc, 6lb pully,42lbfuel injectors,255intank pump,1 3/4headers,highflow cat, borla ajust. cat back,chrome moly LCA,chrome moly ajust. panhard bar, Kenny Brownweld-in subframe conectors, built trans. kevlar lined 2600 stall, kevlar clutches, hardend parts,,built rearend; moser axles, eaton posi, richmond 3.42 gears, rare ROH ZR6 17* 9.5 wheels, custom computer tune with laptop and LT1edit , 380rwhp 395rwtq , 60' 1.71, 1/8th 8.00,1/412.60@109mph
If you want a good ride quality with a good drop, go with Intrax springs.Originally posted by roastmi dont want my car to be too low and i dont want the ride to SUCK eather ,
There is more info in this thread:
http://www.f-body.com/forum/showthre...ghlight=Intrax
Better springs and shocks will definitely help to control the car under hard cornering and braking.
Lots of times people overlook the entire role of the torque arm. It serves 2 purposes...controlling the pinion of the rear end, and body control while braking. It sounds like you would benefit from a new torque arm mount and ideally a better and sronger torque arm.
