I have a 94 Z28 and i am installing an old school carbed small block and i was wondering if anyone has done this and what type of distributer will fit or is a crank trigger required. Also if anyone has any information to give on tips to makeing this work i would like to hear it.
4th gen car/1st gen motor
There are a number of people running a Gen 1 SBC in a 4th Gen chassis. You can fit the distributor under the cowl. Getting it out is another story. Some people will opt for a crab-style cap to reduce the interference with the windshield wipers.
The other problem is going to be the intake manifold and carb. Its going to require a cowl style hood, although I have seen an SS hood modified to clear an injected Gen 1 SBC in a 4th Gen.
You might want to go to CamaroZ28.com and do a "search". There are quite a few threads there discussing the problems you will face.
http://web.camaross.com/forums/index.php?
what is the pump on the front of the motor that is piped into the valve cover??Originally posted by Injuneer
Crankcase vacuum pump. There's a vacuum relief valve on the valve cover on the other side that lets air in as required to keep it from pulling too much vacuum.
View from the other side:
