I've been running these for several hundred miles of use, 15x3s and 15x10s. I've noticed that when pulling in and out of my garage, I detect an occational creaking sound coming from the wheels. It's a faint sound... I mean really faint....... and I can't tell if it's from the fronts or the rears. The lug nuts are nice and tight, the wheels run true and there seem to be no adverse effects..... just the occation light creaking sound that sounds similar to a hinge that needs a little oil in one spot. I've heard of some issues with these due to the way they are manufactured but it doesn't seem to affect the wheel's function. Anyone else run into this?
Those with Weld Pro Stars, inside please
Do you have all the washers facing in the correct direction?Fred
Centercaps? I dont have weld wheels, but the centercaps on the telstars make noise now and then.....96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
The washers thing was just a stab in the dark..... I always seem to find one or two facing in the wrong direction when I polish the wheels.
The center cap is a good place to check.... great idea. Mine (only have them in the front) rattled to the point where I put duct tape on the back of them to hold them in the wheels.Fred
