brake problems / low track lights up
  • brake problems / low track lights up
    looking for answers, any help will do. After getting brake job done. when stepping on the brakes the low track light comes on an the car feels like it rotates alittle an the whole car shakes,then comes to a stop. some times if you tap the brakes the abs inop light will come on an stops the problem. but i might add it is a everyday thing now.
    Most likely your ABS sensors are not functioning. You have one in each front hub, and for the rear you have one in the top of the differential. I would pull the harness connections, clean them and reconnect. That is often enough to get the system working again.
      thanks , i 'll give it a try.
