Hello all. I got home last night from SW Asia and I got the bird out of storage. It started up right away and everything is OK except the AC. I tried to recharge it wasn't taking any gas, because the compressor wasn't locking up. I shorted the pins on the sensor but I could only get the fans to come on, not the compressor. What is my next step?
AC Recharge
Thanks for the welcome back. I'll only be home a couple weeks then back to the sandbox. Anyhow I did short those terminals on the wire connector for the pressure sensor. Haynes didn't say which 2 of the 3 wires to short (gray, black or red) but no combination turned on the AC clutch, but it did turn both fans on. I tried to get to the AC clutch control connector (PITA) the schematic shows on wire DK GRN/White, but of course it has 2 wires. A green and another wire. It is really hard to get to. I would like to send 12V to the compressor to see if it will clunk, but I don't know exactly where I should do this.
Also I did check out the relays. I swapped the ac relay with a fan relay. The fan ran with the AC relay, so that is not the problem either.
99 Silver Z28 A4, T tops, ZR-1 wheels (SOLD)
