Thanks to Steve, I was finally able to finish the turn signal pivot install. I still need to take apart part of the assembly again, though. I need to fix the wire routing of the windshield wiper switch (wires preventing the turn signal from holding down for a left turn), and I forgot to put in the locking screw for the ignition cylinder (stupid me). These are easy to fix/minor things, though.
The problems: as we're testing driving it, we notice that the car shudders as I turn the wheel, once in a while. I checked the power steering fluid, and it's low. So hopefully, filling it will remedy this. Then, as I try to put the drivers side window up/down, it moves cockeyed, then stops. Eventually, I got it to go all the way back up. It turns out, we're positive it's the same problem as Casey's. Although these are minor problems, why do several problems seem to happen all at one time?
Maybe I should look at the bright side...while I'm working on the car, it maybe better for problems to show up, rather than at work or on a trip.
