We traded in the 4 banger minivan for a used 6 cylinder last Friday. The tires on it are 215/70 X SR15 Michelin Harmony tires. The tire says max inflation pressure is 35 psi. http://www.tirerack.com/tires/Spec.j...m=17SR5HARMONY However the sticker on the inside door says to use 36psi. I hate running it at the max. That typically means no margin. What should I run them at?
If it wasn't for the chart saying 1620 lbs per tire I would say the tires are not strong enough for this application. I've never run into this before.
Thanks,
Jeff
Thanks,
Jeff
