I live in Central FL so I have sand and other crud all over my engine compartment. How do I go about cleaning it while not hurting my opti since they tend to be sensitive to moisture? Any help getting my dirty engine compartment sparkling would be much apreciated. Thanks in advance.....Later
How do I clean my engine without killing my opti?
Thanks again.
Not too much sand, just a little gritty. This will give me something to do while the epoxy is curing on my headlight motors after I put in the new brass gears. Besides I'm sick of looking at a dirty engine....Later
Blow solids like sand out with a compressor. Vacuum where you can. Generally, avoid getting water on any of the electrical connectors, the Opti, the PCM, etc.
One of the best cleaners for sensitive areas is "brake cleaner".... leaves no residue. Avoid breathing the fumes as much as you can. For stubborn stains use some solvent like Simple Green on a toothbrush or a Q-tip. Dry well with a rag, avoiding water if you can.
Clean metal parts with Motrhers Aluminum Polish. You can get the fuel rails shining like mirrors with minimum work. Clean the rubber and plastic parts with a wet/soapy rag, get all residue off, then treat with Mothers Back to Black.
Once you get it clean, keep it clean with periodic wiping with a dry cloth. My engine has never been washed.....
Only a real car guy would ever get to the point that he is cleaning his car with a Q tip or his toothbrush... Of course, I've never done thatOriginally posted by Injuneer
My biggest problem is that I mix my laundry with my polishing rags and end up wearing stuff that was a rag for a couple years. Drives the missus crazy!
