Normaly my sterio works fine, but recently in the mornings or evenings it has been acting up. When it is cool and I first start the car the sterio will come on. After about 20 seconds it just shuts off and the display goes dead. When I push the time button it will display the time for a couple of seconds then goes out again. No other buttons work. Ussually when the car heats up the sterio will work fine again, untill today. I have drove it for over an hour, and it is still dead. Any ideas were to check, or what would cause this? It is the stock casette deck wtih the 12 disc changer in the trunk.
sterio dies
Sounds most likely like a dying head unit, but it could also be a ground problem within the cabin or even possibly a chassis ground.
Factory head units can be found very cheap on eBay or other places. I know where several are around here that work fine I will let go for very cheap if you end up needing one.
