Hi Guys!
I have a 1997 Z28 with 86Kmiles on the clock.
First, let me tell you what I have done to the car...I have replaced spark plugs and wires, EGR Valve, Ignition coil and Ignition Module, MAP sensor, IAT sensor, Cleaned the throttle body and replaced gaskets in it, New fuel pump(AC Delco). I also cleaned the Mass Airflow sensor.Brand new Optispark distributor done by dealer!
Now the problem....It takes 3-5 seconds of cranking to start up. When it is idling, you can hear popping in the exhaust like it is missing a little. It seems to bog a little bit too like it isn't getting enough fuel.
The only things left to replace are O2 sensors Mass Airflow sensor, engine coolant temperature sensor, and knock sensor.
Now it doesn't matter if it is cool or hot it still does the above just the same.
Looking at the car on a scan tool the O2 sensors change rapidly.
It has 19.5 Hg of vacuum.
IAC Counts are 30
Long term fuel is 132 on left and 130 on right.
Fuel Pressure is 43psi idling to 46psi if you blip the throttle WOT.
Do you think I need to replace all the injectors and fuel pressure regulator?
IAC Counts are 30
