I just finished changing the opti and waterpump on my camaro, everything went well and turned out great. Since my quad is sold and the golf course is in full action, i have some dinero to maybe spend, the rest is for college. I know some of you guys have very good understandings on cams and parts needed. I was reading about good cams that pull hard from mid-high which is what im looking for. Do they have that awesome idle sound also, and what else will i need to get if i do a cam. Im planning on keeping stock heads too. It would be great if you guys could give me some advice and maybe estimates on past experiences with this engine mod. I love the sound of those lt1's with cams!!!
Engine Ideas
Engine Ideas
Tags: None
Before you even think about changing cams, you need other work first. You should look into headers as your next mod. It will change the sound, give you more HP and torque, not to mention that down the road when you change cams the engine can breathe. Without that, a cam change is hardly worth it.....
An engine is merely an air pump. The path in and out must be modified to be free flowing with no restrictions. Until you do that, changing the amount of air that the engine tries to move (bigger cam) will not result in satisfactory gains.
Originally posted by Joe 1320Before you even think about changing cams, you need other work first. You should look into headers as your next mod. It will change the sound, give you more HP and torque, not to mention that down the road when you change cams the engine can breathe. Without that, a cam change is hardly worth it.....
An engine is merely an air pump. The path in and out must be modified to be free flowing with no restrictions. Until you do that, changing the amount of air that the engine tries to move (bigger cam) will not result in satisfactory gains.1996 Z-28 6 speed, Airfoil, K&N FIPK, Flowmaster muffler, Motive 3.73 gears, BBK shorty headers, cut-out, LS1 Driveshaft, no power options (Rare), Prothane tranny mount, MSD 8.5mm wires, Accel U-Groove Plugs, Chrome hurst short throw, TB Bypass, ES Torque arm mount, BMR subframe connectors (weld-in), Lt4 Knock Module, Descreened MAF, '02 SS wheels, Pioneer HU, MTX & JL amps, 2 12" JBL's, T-Top Conversion!
I found pacesetters long tubes at summit for 429 dollars. Coated an they have the AIR fitting on them. Which y pipe with dual cats can be linked to this. I am definetly doing the exhaust so i need some help. What does deleting the EGR valve do also. Thanks1996 Z-28 6 speed, Airfoil, K&N FIPK, Flowmaster muffler, Motive 3.73 gears, BBK shorty headers, cut-out, LS1 Driveshaft, no power options (Rare), Prothane tranny mount, MSD 8.5mm wires, Accel U-Groove Plugs, Chrome hurst short throw, TB Bypass, ES Torque arm mount, BMR subframe connectors (weld-in), Lt4 Knock Module, Descreened MAF, '02 SS wheels, Pioneer HU, MTX & JL amps, 2 12" JBL's, T-Top Conversion!
I looked up the emission tests for my county. It says the only tests are on-board diagnosis check and the gas cap check. So would Pacesetter emmision legal headers witht there y pipe and cats welded into them work? I would have AIR, EGR, Cats, and O2 sensors. Right???1996 Z-28 6 speed, Airfoil, K&N FIPK, Flowmaster muffler, Motive 3.73 gears, BBK shorty headers, cut-out, LS1 Driveshaft, no power options (Rare), Prothane tranny mount, MSD 8.5mm wires, Accel U-Groove Plugs, Chrome hurst short throw, TB Bypass, ES Torque arm mount, BMR subframe connectors (weld-in), Lt4 Knock Module, Descreened MAF, '02 SS wheels, Pioneer HU, MTX & JL amps, 2 12" JBL's, T-Top Conversion!
