I'ma give Dex-cool one more shot...gonna spend the weekend flushing and cleaning...then a fill. We'll see where this one goes...hopefully it won't go to the crapper.
dex-crap coolant
Temp Gage not Defaulted...
Not sure on the 99 temp gage, but on my 2000 the temp moves slowly from 100* and stays quite a bit from the center point (210*) and runs at 195* and fan kicks on at 210* so not sure about the temp gage just defaulting to the center. Gage shows near exact temperature. Can't go wrong with Pre-Mix unless you want something other than 50/50 mix.1988 5.0 TBI Camaro 700R4 Transmission
I have changed from the Dex to the green stuff and have not had a problem since. I dont know what it is, but some people say they have never experienced an issue with Dex, and others (like myself) hate it. Maybe its climate or something?....or distilled water like Joe says? Every vehicle I have owned that has had Dex sludges up......and I am a fanatic about maintenance. The green works just fine and its cheaper.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
What is the best thing to flush out the sludge. The first time I changed out my coolant in 2005 it was clean. I was getting ready to change it this year 2010, and the radiator cap has sludge. The recovery tank also has some. The service manual says to drain coolant, turn drain plug and open bleed valve on thermostat, remove knock sensors on each side of engine, drain. Re-install sensors, fill radiator with water to filler neck, run engine, let cool, and drain again. Repeat all steps until liquid from knock sensors are colorless. Sounds like a time killer for the engine to cool and repeat the entire process. Now I know why the dealer charges so much. I didn't do this the first time in 2005 which might be why there's sludge since old coolant remained in the engine? It also states to remove and clean recovery tank. Has anyone removed the knock sensors before? Is it hard? Thanks.1988 5.0 TBI Camaro 700R4 Transmission
Originally posted by Reaper383I actually switch my coolant to the Mopar 5 year (i work for dodge so it was free) and I've not had a single problem and also have not changed it in over 5 years (car only has 30k on it)1988 5.0 TBI Camaro 700R4 Transmission
Changed out the coolant and I was over-reacting. There was very little sludge, and most of it was on the Radiator Cap and Coolant Recovery Tank. Flushed out the entire system 5 times until the liquid was colorless. Closed everything back up and filled it up back with Dex-Cool for another 5 years. The radiator was so clean without any traces of contaminants it looked brand new. Next weekend is my Silverado's turn.1988 5.0 TBI Camaro 700R4 Transmission
I'm happy using a light ratio of universal green with water (about 85/15) for a summer mixture, along with some silicate additive such as 'water wetter'. I also run this with a lower than stock fan temp setting. I've been able to get a few extra degrees of timing throughout the range without detonation on just plain old 93 assuming the fuel batch is ok.
ohh yea, It never sludges up on me either
Dexcrap gave me problems the few times I have used it in the TA even with a relatively more stock setup in the past, seems fine in the bonneville and grand prix however.-Alex
ZO6 wheels (clones)
With questionable guts:
Forged bottom end
pacesetter longtubes
K&N RAM air from 96 ws6
96? ws6 hood
96? ws6 spoiler
full emissions delete
Edelbrock IAS shocks
I got some stp cooling system flush . anyone used that or someting similar, is it safe to use?
I switched to prestone green a while ago , and its all good, didnt notice any sludge. flushed the system with a garden hose and let the engine run , maybe 7 times before refilling with new coolant though. there was sludge and coolant dirty before canging it, noticed in the other cars too. the green coolant appears to stay clean and not 'break up' like the dex cool. i m no expert though93 t/a A4 3.23s
99 Alfa Romeo 166 3.0 v6, red
97 3.8 v6 A4 camaro, hardtop
00 audi a6 4.2 40 valve v8
