Hi Guys!
Well I changed the fuel injectors and fuel pressure regulator. Believe me the injectors were dirty and the fuel pressure regulator was bad too!
Although this helped a lot, it still studders and pops in the exhaust. But not in the intake.
My car has a new opti that was installed by the dealer!
The dealer also installed AC Delco Plugs and wires. I have put New EGR Valve, Map Sensor, and Intake air charge sensor.
I have cleaned the Mass Airflow sensor and the throttle body ( I put new gaskets in the throttle body.
Is there any way to test the OptiSpark distributor or Can the dealer test it?
Could the O2 sensors be bad and not turn on the light. Would that make it studder and idle strange?
Guys I am open to suggestions!
I am going to get a scanner what would you recommend?
Thanks Lee!
Thanks Lee!
The IAT? Also, have you checked your fuel pressure after you changed the injectors and regulator? How about the fuel filter?
