Which brand of 4.10s?
  • Which brand of 4.10s?
    Which brand of 4.10 gears should I get. I am considering GM, SLP, and Richmond. I have always had good luck with Richmond gears, but.... The 4th gen is a different animal.
    '77 K5 rock-crawler project
    Thomas Jefferson
    Well, I will say this. DO NOT get Richmond. They are very noisy.
    I would say you have two choices: GM (or Motive) brand or US Strange. I liked the Strange because of lower cost and dependability. However, GM are just as good, just a bit pricier.
    Make sure you "upgrade" the rest of the components while you in there. Cheap insurance against premature breakage.
    Al 96 Ram Air T/A
      GM has the most sucess in f bodies. get the install kit too. use synthetic gear oil (mobil 1. and add one bottle of the addititive for the cluster gears).
        What upgrades do you recommend? Do you recommend a kit? I found the Strange gears at Thunder Racing. I just need to get 4.10s installed until I can afford to get a Strange or Moser 12 bolt. I don't think I will break anything, hopefully. I don't do a lot of hard launches on slicks or anything. I have directional/semi-aggressive 315/35/17s on the rear that are pushed on a course or track. It is really lame that GM didn't use a 12 bolt stock.
        Thomas Jefferson
          Where is a good source for these?
          Thomas Jefferson
            Two places I've used before are www.tbyrnemotorsports.com and www.thunderacing.com
            Thunder Racing had the best gear package for me since I needed gears for series 2. Also purchased the higher end install kit....basicaly have a "new" rear diff now.
            Joe K.
            '11 BMW 328i
            '10 Matrix S AWD
              I am excited!!!
              I just called the differential builder I used for my Blazer just out of curiosity. He did an excellent job on the beast so maybe he will do this. He does mostly big trucks so I didn't know what he thought of my 10 Bolt. Anyhow, he apparently does a lot of them, and he keeps a good supply of Strange gears and install parts. Well, he is going to do my gears, 4.10s, including parts and labor for $525. He concurred that the Richmond's are not that great. I am excited, and I plan to set the appointment next week.
              Thomas Jefferson
                Upgrades...
                Get yourself some trick parts from Ratech...I've used them for three years now, they work great and are cheap insurance.
                One is the solid spacer. It is a great improvement over the crush sleeve.
                The other is the Bearing cap studs. They replace the flimsy bolts to keep the bearings from twisting and prematurely wearing. Both Ratech kits are real cheap. I got mine directly from Ratech.
                Finally, I would suggest a good aluminum diff. girdle/cover. While I'm not sure if the added ridgity helps any, the preload bearing cap bolts help to keep the bearing caps from twisting...kind of double insurance against loosing your set up and spacing of the gears.
                My Strange set up has lasted with no problems. I paid $165 for the 4.10's, $99 for the install kit, $50 for the Ratech parts, $110 for the diff. cover, about $5.00 for the fluids, and $225 for the install. I also installed a take-off Torsen differential that I picked up from SLP for good measure.
                Best mods. I've done to date. Have you thought about how to calibrate your speedo???
                Al 96 Ram Air T/A
                  Re: Upgrades...
                  I will ask the builder about the Ratech parts you mentioned. I have an HPP3 so I can set the PCM with that. I use it for the fans, and I installed the power program for the heck of it. It made the car respond a little better at this altitude. I do need a custom program though because of the altitude. Eventually, I will get LT1 edit and play. The stock program is just a little too rich...bummer, and lot more costly then new jets on my Carter AFB in the Blazer
                  Oh, do you have a number for ordering the parts from Ratech?
                  Thomas Jefferson
                    Try this...
                    http://www.store.yahoo.com/ratech/75gmaxle.html
                    Al 96 Ram Air T/A
                      I bought the Superior Gears from Tom Byrne MotorSports. They are also GM factory gears.
                      Anyways, the install kits that you get are WORTHLESS.
                      The Helm's manual says to throw away
                      the factory spacers, as they may break when
                      reinstalled.
                      There is no way that differential is going back
                      in with those spacers if you put new side
                      differential bearings on. Maybe that is why
                      so many shops FAIL on gear installs.
                      GM has real side bearing replacement shims
                      from .030? thru .080?
                      The ones in the "install kit" were like .012, .013,.011, .010.. WTF
                      After test fitting the diff, (and using a feeler
                      gauge to find the correct thickness you want),
                      you have to add/remove from each side
                      to change backlash.
                      Then once you find the correct setting, you
                      increase each side by .004 and install those
                      shims. That makes the differential tight.
                      I ended up moving my differential to the left
                      quite a bit.
                      Those Helm tools are expensive, but I did
                      the job right!
