Here's one for that HP formula you have. 87 Omni, 2400 lb race weight, 103mph trap speed. What do you come up with?
Injuneer -whats that formula again?
Tags: None
I get 205 flywheelHP. With a perfect launch and 100% utilization of the available power, the car should run 13.1-13.2. For an average launch, it will only run mid-13's.
But you are getting a bit far away from the typical car that I have tweeked the formula for, which is a 3,000 - 4,000# rear-wheel drive, running in the range of 9.0 - 15.0 seconds.Fred
Thats my winter rat, I just wanted to see what you came up with. I think 205 HP is pretty darn close. I've only got it into the low 14 with street tires with copious amounts of wheel spin in 1st and second when the turbo kicks in. It is fun though - its a real P.O.S.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
Is it a GLH?Fred
No, its a homemade GLHS. It was a regular carbureted automatic and I transplanted an intercooled 2.2 with a 5 speed. Its all rusty and generally looks like a P.O.S.
It sure does take a lot of mustangs (and even some f-bodys) for a surprise, especially from a roll.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
