dose any one have control arms with the Spherical Rod Ends. wondering just want to know how much louder they are than the stock because im think about building a set be cause its a lot cheaper any help or input would be great
control arms
Originally posted by formula14.18does any one have control arms with the Spherical Rod Ends. wondering just want to know how much louder they are than the stock
Quality rods ends will run you about $25 each. They have to be top of the line, like the QA1 Kevlar lined ends.
I have rods ends on my lower control arms and torque arm. Very "solid" and a bit on the noisy side... but as Joe points out, the exhaust, and the rattle from the solid roller motor are so loud that I can't hear much of anything in the car anyway - I've already deleted the stereo . But its a track car, not a street machine.
One compromise for a street car would be a poly bushing on the body end of the arm, and a rod end on the axle end to eliminate bind.Fred
Well I'm not sure about the rod ends but I bought the BMRs with poly/poly ends. About 2 weeks ago I got tired of the noise and ordered rubber replacement bushings. Even the polys are too loud for me. When I through my car in a hard left turn I can hear the right rear bearing. I can't hear the left one on a right turn though. I've been too busy with other things to put them on though.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
well i think im going to try it but im going to make the panhard bar first the rod ends that sphon use are only 23 dollars each and the tube adapters are only 8 bucks so its it will only be about 70 bucks1995 formula firebird
mods k&n fipk ,flowmaster catback, 52mm throttle body, crane hi-6 with lx92 coil,mad dog tranny with trans cooler
