Steering wheel vibrating
  • Steering wheel vibrating
    When I go over bumps or hit pot holes, my steering wheel moves excesively. It's not really a vibration, it moves alot. I was wondering if you guys had any ideas of what could be messed up. It doesn't move when the car is parked or riding on a smooth surface, so I don't think the wheel itself is loose, just something in the front end. Thanks fellas
    1999 Ram Air Trans Am. M6
    SFC( not sure what kind), drilled/slotted rotors, K&N air filter, all free mods, 3" Borla cat back exaust, electric exaust cut out, NGK spark plugs, royal purple motor oil, and Zaino .Maybe more. I find more stuff done to it everytime I look at it.
    excessive play in the tie rod ends maybe.. better have it checked....
      Idler arm, tie rods, or a really, really bad ball joint. But the ball joint would be obvious if you made a sharp turn at full lock as it would feel like the front end "popped" towards that corner.
        Time for relignment work. Had the same problem.
        Hercules
        2008 Sunburst Metallic HHR LT
