Hi Guys!
Well, if you will remember me telling ya about my car's popping in the exhaust!
After replacing the O2 Sensors and Air Check Valves. It ran much better but after driving it again. It is still doing it.
It will do it in Open loop, as well as, Closed loop.
Do you guys think that when I had the dealer do my plugs and wires that they just really didn't change the plugs and just said they did.
I noticed that there is some oil leaking from around where the optispark meets up with the motor. Do you think oil could have gotten in the opti?
I put new Delphi 24lb injectors, AC Delco wires, plugs, EGR Valve, Map sensor, IAT sensor, Fuel Pump, Water pump, Air Check Valves, and O2 Sensors.
I had the PCM programmed by PCM for less.
The BLM's for left show 160 and right 154(Long Term). However, the (Short term) reads for both the left and right show 127-133. So why would it make the BLM's for Long Term be 160 and 154.
Could this be the way Bryan has the PCM Programmed?
If it was a burn't Valve wouldn't it not have very much power? If it were a head gasket wouldn't it use oil or Antifreeze?
Thanks Lee!
Thanks Lee!
