I am looking at doing quite a bit of suspension work to my formula. I was thinking about getting a set of full triangle subframe connectors. I have seen these on ebay for pretty cheap if I want welded ones. Also is one better than the other in regards to bolt on or welded? I was also thinking about torque arms and sway bars. The last two possibilities are the strut tower brace and new panhard bar. Any input on where to pick up some of these at a reasonable price would be greatly appreciated.
suspension
Help
Someone has got to be out there that can help me out with some ideas.slp longtube headers, slp y-pipe, high-flow cats, superchips programmer, slp 85mm air sensor, slp loudmouth exhaust, ws6 hood, slp cai, kn air filter, slp high-flow lid, smooth bellows, tb bypass, subframes, lca's, panhard bar, torque arm.
www.bmrfabrication.com
They make excellent susp. stuff. Lotta guys on here swear by them. I'm running their Lower control arms, relo. brackets, and adj. panhard bar. Very nice stuff. I wouldn't buy any no name stuff off ebay. I have even heard of a lotta people buying edelbrock stuff and having it break leaving the shop that installed it. There is a guy on here with a big power Formula running all Spohn suspension. I would go with one of those two.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
2001 Trans Am WS6 M6
