I have a question for the F-bod gurus. The light on the right hand set of steering wheel mounted stereo controls on my bird has burn out. How do I go about replacing it. I don't want to just start prying on itand break something ya know. Any help would be greatly apreciated. Thanks in advance.......Later
New lights for steering wheel controls
The whole thing is a unit. You can save your self time by replacing the control for about $65. from GM parts direct.
But if you know how to solder you can replace the light bulb in it but its not easy.
The control will just pop out a little and you have to disconnect the module. Its got a plastic clip molded on it. Its a PITA to get to though.LT4KM, 160' TS, MAF ends, TB-bs, 1.6 R/R, SLP CAI, LCA, tierod, 17x9"F/R, 275/40R17 tires. WS6 Muffler, LS1 DS. 21mm rear sway bar. Soon to be LT4 heads, intake, & HOT cam
So do I just pry it out gently? I think I'll try to fix it $65 is a rip off. I mean why make a light bulb that can't be replaced? Thanks again GM
If I screw it up I'll just try and find one on ebay. Thanks again.............Later
