I have a 1999 firebird V6 and I am having a problem with water leaking all over the passanger floor. I know that this problem is from a clogged drain hose, but I cant seem to find it anywhere under the car. Is it true tha I have to take apart the dash to get the the condensor box?
AC leaking water all over the floor
jms10446Tags: None
I've actually had this same problem. For some reason, my car does not have a hose, just a hole in the box itself. If you get under the car and look up near the starter area at the back of the motor, you will see it. Mine was one freaking leaf causing all my problems. It took 3 days to dry the carpet out (that's with it removed from the car). Of course, it took me 4 months to getting around to putting it in again."No, officer, that bottle is my onboard Halon system"
Though this is on an LT1 car, you should find the drain hole here.Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
