Hey guys, I have a 95 T/A 6spd 100% stock and i noticed today that when i go over 75 in 6th gear it starts making this wierd vibrating noise, its not consistent its like rrrrrrrrr........rrrrrrrrr.......rrrrrrrrr and its seems to get louder the faster I go. I have also heard it in 3rd once in a while but never paid attention to it, anyone heard of this or know what it could be? Appreciate the help!
Vibrations
Most likely and out of balance driveshaft. Years ago, the factory put out a technical sevice bulletin that addressed the problem. The factory fix was to replace the out of balance steel unit with the 1LE aluminum shaft. Not much you can do except replace the shaft.
It could be tires, but a quick trip to the tire store and the balance checked would rule that out.
Originally posted by Joe 1320Most likely and out of balance driveshaft. Years ago, the factory put out a technical sevice bulletin that addressed the problem. The factory fix was to replace the out of balance steel unit with the 1LE aluminum shaft. Not much you can do except replace the shaft.
If you know your wheel weights are missing get them balanced before going any further. If it still vibrates get an aluminum driveshaft. They are pretty inexpensive.Tracy
