Recently my Trans Sport (info in sig) has developed a stumble at idle. It starts up and runs fine, but after the engine has warmed up and is at a steady idle the rpm's will drop intermitantly, about 200 rpm, sometimes the drop is enough that the engine will die. It does this in drive and park, no set time interval between drops. No SES or codes. I've replaced the fuel filter (it was only 8 months old). I plan on cleaning the throttle body and IAC this weekend. Could it be dirty injectors? EGR? What else should I check?
nfb: what else to check?
Bruce, μολων λαβέTags: None
clean the mass air flow censor with a q-tip and some intake cleaner but be carefull and dont break the wires. and im not sure if gms have the idle air control vavle(my old taurus did what ur van does and i cleaned that and it fixed it)2009 Honda Civic EX- the daily beater
