305 vs 350?
  • 305 vs 350?
    I just got a swap from a 305 to a 350, so much more power. But how do you know its a 350? it looks the same as a 305? is there any indicators on the engine that tell its is a 350? Or just does the 305 and 350 look alike?
    Thanks,
    You need to check the casting numbers on your block or heads. Then look up the numbers in a reference like www.mortec.com. Then you'll know if you have a 305 or 350.
    Bruce, μολων λαβέ
      k well I got the numbers, but they don't match any numers on Mortec.com, the #'s are.
      14057055
      CMk11
      Are those the right #'s I am looking for, I found them like right under the driver side of the carb.
        those would be on the manifold... you probably want to look on the block itself, or possibly the head.
        Dave M
          Nah, its not on the Manifold, its like right above the block. Right of the carb.
            If you're looking next to the carb, those numbers are on the intake manifold. You need to look behind the driver side head on the block. number 3 in the diagram. If it's a later year block it may say 5.7L in that location.
            edit: just verified that 14057055 is inded a SBC intake manifold.
            Bruce, μολων λαβέ
              yea that diagram is a lil odd so just incase ur not sure.... u gotta look right where the bellhousing bolts onto the back of the block.
              1967 Camaro "Project"
              1972 Chevelle "454"
              1979 Trans Am "Project Ls-1"
