My sensor looks rather nasty and I want to try to clean it up a bit. I just want to find something to spray on it though since it is such a sensitive sensor.. Would some throttle body cleaner work or would that be to strong?
Best way to clean the MAF?
Get some electric contact cleaner at radio shack. Spray the elements down and very gently clean the 3 elements with a wet swab. Yes they are fragile but they can be cleaned without worry. Just do it carefully.
My engine seemed to run smoother after doing this.1995 Z28 Convertible, 350ci LT1 73K miles M6.
