I stole this from another forum, so I can't vouch for it's authenticity, but it's an interesting read.
What does Mobil 1 have in common with a fine wine? They both get better with age.
This is a must read:
http://neptune.spacebears.com/cars/stories/mobil1.html
Among the more interesting quotes:
"Engine wear actually decreases as oil ages. This has also been substantiated in testing conducted by Ford Motor Co. and ConocoPhillips, and reported in SAE Technical Paper 2003-01-3119. What this means is that compulsive oil changers are actually causing more engine wear than the people who let their engine's oil get some age on it."
"While the wear metals all accumulated steadily over the course of the test, the highest concentrations of accumulation per mile occurred in the first 3,000 miles of the test! From the 3,000-mile mark all the way to 18,000 miles, only lead showed an increase in per-mile wear beyond 3,000 miles. Yet even with an increased wear rate, lead wore the least in terms of absolute wear. For iron and copper, the longer the oil remained in service, the lower the wear rate got."
"Topping up the crankcase is a critical component of extended oil change intervals, and frequent filter changes are most likely the key to extreme-length intervals. The cumulative effect of even minor top-ups, let alone a filter change, substantially increases the longevity of the oil."
From another article:
"One interesting point is that fresh oil will have a
higher wear rate until the ZDDP antiwear is activated(oxidized). The
wear rates of some 60-70 oils that I have tested improves over the first
1000 miles or so.
Edward B. Kollin
exxon Research and Engineering Advanced Fuels and Lubes Group"
1000 miles or so.
Edward B. Kollin
I still change it every 3K
