true ws6 or not?
  • true ws6 or not?
    Just got it in. Vin#2g2fv22p7v2206251
    Its got the wheels, hood, and the badging but you all know how that is.
    Thanks
    current
    You won't know by the VIN unless you get the dealer to print out the options. Find the option sticker and it should list WS6 somewhere on there if it is real.
      Where is the option sticker located?
      current
        it should also be on the RPO plate on the drivers door
        1997 Trans AM WS6 vert
        1 of 463
        LT4 knock module
        strut tower brace
        SLP fan switch
        160* t/stat
        Pictures Here
          what code should I be lookin for? Thanks
          current
            if you wait till tues. i can print out everything about your car, all the option codes, delivery date, warranty repairs, you name it.
              My SS has sticks on driver's & passenger drs.---both different. Maybe check both doors, as my passenger gave the detailed SLP opt's.
              Good luck!
                I dont think the WS6 cars had the second content sticker ..at least mine dosent. may just be a 97 thing. But the tag on the drivers door has a ton of three letter codes. if its a real WS6 one of the codes will be WS6
                Here is a link to the Pontiac RPO codes
                RPO codes
                1 of 463
                LT4 knock module
                strut tower brace
                SLP fan switch
                160* t/stat
                Pictures Here
                  the WS6 does not have an SLP build sticker. The SS and Firehawk would have that second sticker. As was said before, lookf for RPO code "WS6".
                  Dave M
                    DUH!!!! Sorry about that I feel like an idiot.
                    Wolfman that would be great.
                    current
