Went to that race warriorz thing. Terrible. Packed, totally packed. Waste of time and money! I got one run in the entire 5 hours I was there!
My car was getting hot from
in line for 2.5 hours. I kid you not guys, when I First got the car, on hot days, the throttle would stick sometimes at like 2500, 3000 RPM. Hasn't done it since last year. As I'm getting closer, it starts.
I get to the line and once I hit the gas to rev it a little it started to stick, tree flashed, too late to react, just gunned it. So I took off at like 4000.
2.5xxx 60 ft.
14.2 1/4 mile
Street tires @ 19 PSI.
If I could have launched better I could have clicked off a 1.8 60 ft I would assume. Didn't get to run again. Started to rain about 11:10, so I left.
in line for 2.5 hours. I kid you not guys, when I First got the car, on hot days, the throttle would stick sometimes at like 2500, 3000 RPM. Hasn't done it since last year. As I'm getting closer, it starts. I get to the line and once I hit the gas to rev it a little it started to stick, tree flashed, too late to react, just gunned it. So I took off at like 4000.
2.5xxx 60 ft.
14.2 1/4 mile
Knock problem didn't go away.... pulled up to 11.2 degrees (knock retard) at some points. It was my last few runs with the Nitto DR's... New pair coming monday. Only good part of the day was nabbing a .05x light.
13.410 @ 102.66 11/20/05]
