I can recommend AfterthoughtsAuto.com
  • I can recommend AfterthoughtsAuto.com
    Afterthoughtsauto.com is one of the advertisers on this Board and I can personally vouch for their quality.
    I ordered a set of fuel rail covers from them for my '98 TA. They fit perfectly, even with the factory EGR tube and an MBA throttle cable cover.
    Afterthoughtsauto.com has been great through the entire process.
    I will post pics on my Web page later this week.
    R.i.K.
    '98 WS6 TA (white, of course!), Hurst Billet/Plus shifter, BBK intake manifold, McGard “blue-ring” lug nuts (12x1.5), PowerSlot brake rotors, Hawk brake pads, Stainless steel braided brake lines, Pontiac arrow, Hotchkis strut tower brace, MBA MAF ends, Reflective Concepts lettering, MTI carbon-fiber look airbox lid . . . and one greying, somewhat eccentric owner.
    Looking forward to seeing some pics of the engine, Roger!
      Thanx! I've been wondering about them & haven't really heard anything neg.
      They have an SS red/white grille that would look awesome on my car, but haven't made up my mind yet. Thanks for your .02!
        Good deal man, cant wait to see some pictures.
        -Dan
          Same here... I've been thinking about getting a set of the fuel rail covers. Can't wait to see the pics.
            I've also ordered from them in the past. A good experience
            I'd also like to see pics., and how was the installation?! I'd like to get a set for the SS.
            '99 SS, #1392 Onyx Black/Neutral leather; M6; T-Tops; SLP Options: Perf. Exhaust; Key Fobs; Plaque
            Mods.; SLP L/T's; SLP Y-Pipe; Random Tech High-Flow Cats; SLP Loudmouth; PRO 5.O w/ Lou's Short Stick; MTI Airlid w/ K&N; Hotchkiss STB; OPTIMA Red Top; Chrome ZR1's
              Cover installation
              You will need to follow the included instructions carefully, but there are a few "tricks" that will ease installation.
              Remember, you cannot install these covers if you have a BMR strut tower brace. A Hotchkis STB is not a problem, though.
              On the passenger side of the engine, make sure that you slide the cover under the large convoluted tubing in the back of the engine. It will be necessary to lift the tubing up and slide the cover under.
              On both sides of the engine, it will greatly ease installation if you disconnect the two AIR tubes. You'll need a 10mm socket wrench to do this. Be especially sure to put a towel or something under the tubes in case you should drop one (or more) of the bolts.
              A second set of hands is useful at times to lift wires and such out of the way.
              You may have to bend the dipstick tube quite a bit. Don't be alarmed as they are very flexible. Turns out there is quite a bit of variation from car to car.
              It just takes a little time. Figure about an hour.
              Oh, and don't be too surprised if you scratch the rear of the covers a bit when you place them under the cowling. No biggie as you can't see the rear of the covers that far back anyway. Just exercise a little care and you should be fine.
              R.i.K.
                Pics posted of installed covers
                I've posted pics of the installed covers at my Web page:
                http://www.mindspring.com/~rojo2/today.htm
                R.i.K.
