Really dumb question... what is "NFB" ??
  • Really dumb question... what is "NFB" ??
    Sorry not being down with the "lingo" lol
    An acronym list would be cool in the FAQ section.....
    1997 Trans Am WS6 Black M6
    370 RWHP / 352 TQ
    CC306 & Comp behives, LT1 Extreme Duty timing set, 1.6 RR's, CSR Elec Water Pump, Pacesetter LT's & ORY, GMMG w/ Ovals, K&N, Air Foil, TB Bypass, !AIR, !EGR, !CAGS, 160 deg thermo, LT4 KM, PCM tuning by Total-ReCal, March Pullies, Pro 5.0, 4.11 gears, LS1 alum DS, BMR strut tower brace, UMI SFC's, LCA's w/relo brackets & panhard
    It stands for "Non-F-Body". Use it when posting info not about f-bodies so those who don't want to read it can pass it by.
    Dave M
      Ahhhhh
      Roger that.
      Thanks!
      370 RWHP / 352 TQ
        haha finally someone asked that question. i always wondered...but never asked.
        1996 Trans Am WS6
        A4, 3" VForce Catback, Corvette C6 rims, Slotted and Drilled Rotors, 160*stat, BMR SFC, HPP3, B&M Shift Kit.
          I always thought NFB meant No Free Beer
            Never thought of that one.
              "No Fat B#TTs"
                No Fords, B*tches
                  I didn't know what that meant either. Now if I could just find out what TTT meant.
                    To The Top
                    1995 Firebird Formula
                      Originally posted by wolfman
                      "No Fat B#TTs"
                      hey ... that isn't very nice wolfman!! I resemble/resent that remark!! hahaha... just kiddin'
                      '07 Black Tahoe LTZ (my new baby)
                      '96 White Firebird (sold )
                        Here's a few more, :
                        ! - using this before an acronym means removal of that item from the vehicle (example: !EGR)
                        1/4 - Quarter Mile (drag racing)
                        1LE - Suspension Handling Package Option
                        2WD - Two Wheel Drive
                        4L60E - actual part name for the Automatic 4-speed transmission
                        4WD - Four Wheel Drive
                        700R4 - older generation 4-speed GM automatic transmission
                        A3 - 3-speed automatic transmission
                        A4 - 4-speed automatic transmission
                        A/F - Air Fuel Ratio
                        AIR - Air Injection Recirculation (part of emissions system.)
                        APHR - Adjustable Panhard Rod (Suspension)
                        AFR - Air Flow Research (Vendor)
                        ASP - Automotive Specialties Performance (Vendor)
                        ASR - Camaro version of traction control
                        ATF - Automatic Transmission Fluid
                        ATI - Supercharger Company (Vendor)
                        AWD - All Wheel Drive
                        B4C - Police Package Option
                        BBC - Big Block Chevy engine
                        BBDC - Before Bottom Dead Center
                        BDC - Bottom Dead Center
                        BHP - Brake Horsepower
                        BOV - Blow Off Valve (turbo related)
                        B/O - Bolt-On Modifications
                        BSM - Body Side Moulding - door ding guards on your doors.
                        BTDC - Before Top Dead Center
                        BTW - By The Way
                        C4 - Fourth Generation Corvette (1992-1996)
                        CAGS - Computer Assisted Gear Selection (the "skip-shift" on M6 cars.)
                        CATS - Catalytic Converters (emissions/exhaust system)
                        CAI - Cold Air Induction
                        CI - Cubic Inches (engine displacement)
                        CKP - Crankshaft Position (sensor)
                        CMP - Camshaft Position (sensor)
                        CONV/'vert - Convertible
                        CR - Compression Ratio
                        DEG - Degrees (timing or temperature)
                        DRL - Daytime Running Lights
                        DR's - Drag Radial Tires
                        DSL - Driveshaft Safety Loop
                        DTC - Diagnostic Trouble Code
                        ECM - Engine Control Module
                        ECL - Exhaust Lobe Center Line (camshaft)
                        ECT - Engine Coolant Temperature (sensor)
                        EGR - Exhaust Gas Recirculation (emissions system)
                        EGT - Exhaust Gas Temperature
                        E/T - Elapsed Time (drag racing time measurement)
                        FAST - Fuel Air Spark Technology (Vendor)
                        FBODY - GM chassis designation for Camaro/Firebird
                        FI - Forced Induction (turbos, superchargers)
                        FIPK - Fuel Injection Performance Kit (See K&N)
                        FMIC - Front Mounted Intercooler (turbo)
                        FMS - Futral Motorsports (Vendor)
                        FMU - Fuel Management Unit
                        FPR - Fuel Pressure Regulator
                        FPSS - Fuel Pressure Safety Switch
                        FRA - "Free Ram Air" modification
                        FRC - Fuel Rail Covers
                        FLP - Finish Line Performance (Vendor)
                        FTRA - Fast Toys Ram Air (product)
                        FWD - Front Wheel Drive
                        FWIW - For What Its Worth
                        GMMG - Vendor known for producing modified GM backed F-bodies
                        H/C - Heads and Camshaft
                        HO2S - Heated Oxygen Sensor
                        HP - Horsepower
                        HPE - Horsepower Engineering (Vendor)
                        HPP3 - Hypertech Power Programmer 3 (product)
                        IAC - Idle Air Control (solenoid)
                        IAT - Intake Air Temperature (sensor)
                        IC - Ignition Control Circuit
                        ICL - Intake Lobe Center Line (camshaft)
                        IGN - Ignition
                        IMHO - In My Humble Opinion
                        IRS - Independent Rear Suspension
                        K&N - Brand name of air filter
                        KR - Knock Retard (tuning)
                        LCA - Lower Control Arm (suspension)
                        LGM - Lou Gigliotti Motorsports (Vendor)
                        LM - Loud Mouth (exhaust system by SLP)
                        LMAO - Laughing My Ass Off
                        LOL - Laughing Out Loud
                        LPE - Lingenfelter Performance Engineering (Vendor)
                        LT1 - Generation 2 GM smallblock V8 engine (introduced 1992)
                        LT4 - Generation 2 GM smallblock V8 engine (introduced 1996)
                        LT5 - GM/Lotus/Mercury Marine joint collaboration project, DOHC 5.7L V8 engine found in the Corvette ZR-1 (introduced 1990)
                        LSA - Lobe Seperation Angle (camshaft)
                        LSS - Lou's Short Stick (shifter handle)
                        LT - Long Tube Headers
                        LTFT - Long Term Fuel Trim (tuning)
                        LTRIM - Long Term Fuel Trim (tuning)
                        M6 - 6-speed transmission
                        MAF - Mass Air Flow sensor (measures amount of air entering intake)
                        MAP - Manifold Absolute Pressure (sensor)
                        MAFT - Mass Air Flow Translator (product)
                        MN6 - Option code for factory 6-speed transimission.
                        MTI - Motorsport Technologies, Inc. (Vendor)
                        N/A - Naturally Aspirated (all-motor)
                        N20 - Nitrous Oxide
                        NBM - Navy Blue Metallic (color)
                        NOS - Nitrous Oxide Systems (brand name)
                        NWS - Not Work Safe (do not click link if you are at work, unsuitable material inside)
                        O2 - Oxygen Sensor
                        ORY - Off Road Y-pipe
                        ORP - Off Road Pipe
                        PCM - Powertrain Control Module (your vehicles engine/tranny computer)
                        PCV - Positive Crankcase Ventilation (emissions system)
                        PE - Power Enrichment (tuning)
                        PHR - Panhard Rod (suspension)
                        PITA - Pain In The Ass
                        POS - Piece Of Sh*t
                        P/P - Ported And Polished
                        QTEC - Quick Time Electric Cutout (product)
                        QTP - Quick Time Performance (Vendor)
                        ROFLMAO - Rolling On Floor Laughing My Ass Off
                        RPM - Revolutions Per Minute (engine speed)
                        RWD - Rear Wheel Drive
                        RWHP - Rear Wheel Horsepower
                        RWTQ - Rear Wheel Torque
                        SAE - Society of Automotive Engineers
                        SBC - Small Block Chevy engine
                        SC - Super Charger
                        SES - Service Engine Soon lamp (on dash)
                        SFC - Subframe Connectors
                        SLP - Street Legal Performance (Vendor)
                        SOM - Sunset Orange Metallic (color)
                        SOTP - Seat Of The Pants
                        SS - Super Sport
                        SSRA - Super Sucker Ram Air
                        STB - Strut Tower Brace
                        STFT - Short Term Fuel Trim (tuning)
                        STRIM - Short Term Fuel Trim (tuning)
                        T56 - actual part name for the M6 transmission
                        TA - Trans Am
                        TB - Throttle Body
                        TBODY - Throttle Body
                        TBRAKE - Transmission Brake
                        TEA - Total Engine Airflow (Vendor)
                        TC - Torque Converter
                        TCS - Firebird version of traction control
                        TDC - Top Dead Center
                        TFP - Transmission Fluid Pressure (switch/valve)
                        TH350 - Turbo Hydromatic 3-speed automatic transmission
                        TH400 - Heavy Duty Turbo Hydromatic 3-speed automatic transmission
                        TNT - Texas Nitrous Technologies (Vendor)
                        TP - Throttle Position
                        TPiS - Tuned Port Induction Specialties (Vendor)
                        TPS - Throttle Postion Sensor
                        TQ - Torque
                        TR - Thunder Racing (Vendor)
                        TSP - Texas Speed & Performance (Vendor)
                        TT - Twin Turbo
                        TT2 - Torque Thrust 2 (type of wheels by American Racing)
                        TTOP - T-Top roof
                        TTT - "To The Top"
                        UCA - Upper Control Arm (front suspension)
                        VATS - Vehicle Anti-Theft System (the coded chip in your ignition key)
                        VERT - Convertible
                        VSS - Vehicle Speed Sensor
                        WB O2 - Wide Band Oxygen Sensor
                        WOT - Wide Open Throttle
                        WS6 - Firebird Performance "Ram Air" Package (RPO code)
                        WTB - Want To Buy
                        WTF - What The Fu*k?
                        WTT - Want To Trade
                        WU8 - Camaro Performance SS Package (RPO code)
                        Y2Y - Exhaust Upgrade Option Code for SS Camaro (Dual-Dual system)
                        YBODY - GM chassis designation for Corvette
                        Z28 - Camaro equipped with V8 engine (RPO code)
                        ZR1 - Corvette with LT5 motor, GM and Lotus joint project in the early 90s
                          Forgot one, TY! (Thank you
                            Forgot another, Kevin... LS1
                              BTW - By The Way
                              HP - Horsepower
                              IGN - Ignition
                              N20 - Nitrous Oxide
                              O2 - Oxygen Sensor
                              ORP - Off Road Pipe
                              POS - Piece Of Sh*t
                              SC - Super Charger
                              SS - Super Sport
                              TA - Trans Am
                              TB - Throttle Body
                              TQ - Torque
                              TT - Twin Turbo
                              TTOP - T-Top roof
                              TTT - "To The Top"
                              VERT - Convertible
                              WTB - Want To Buy
                              WTT - Want To Trade
                              Paging an Admin to make this list sticky!!!
                              370 RWHP / 352 TQ
