hah... i know what you're thinking...she didn't read before she posted...and this is just another grinding headlight question, but nope... I like to add a little variety into y'all's lives
...so...
I know that my headlights are making the grinding noise, and I know how to fix it... I'm plannin' on doin' that next paycheck
But, I started to realize that if/when I want to turn on the parking lights, the headlights pop up... they don't come on, just pop up... My question to you is... when I change to metal gears and I'm not runnin' on the jacked up ones, Are my lights still gonna pop up when I want to turn on the parking lights?? And if so, is there an adjustment that I should/can make to the lights while I'm changing gears??
...so...I know that my headlights are making the grinding noise, and I know how to fix it... I'm plannin' on doin' that next paycheck
That just might be the start of a bad switch. It could also be related to the headlight motor as well. If you unplug the harness of the bad motor, see if the good headlight still pops up when you turn on the parking lights only. Unless of course both are bad.......then it's fix them first and go from there.
it's the rotary switch to the left of the console. The only pain is pulling the cluster bezel and not scratching up anything.
Thanks again!
