hydraulic clutch
  • hydraulic clutch
    could some please explain how/what it is? I know its a clutch but don't really undestand how it works and how it differs to other clutches.
    thanks
    97 TA, M6, JBA ceramic coated headers, Borla Cat-back exhaust, 1.6 RR, 160 Thermo, LT4 knock sensor, CAI, Bils, Hotchkis all around, GT rotors, B&M shifter, Magnecor wires, Granatelli MAF
    In the shop LT4 Intake and heads.
    runs of hydraulic pressure instead of a linkage
      There's a hydraulic "master cylinder" on the firewall that is operated by the clutch pedal, a braided S/S line that connects the master cylinder to the "slave cylinder" on the side of bellhousing (LT1) or front of the tranny (LS1). The slave cylinder on the LT1 presses on the clutch fork, pushing it forward, and it "pulls back" the throwout bearing, releasing the clutch. On the LS1, the slave cylinder is concentric with the tranny input shaft, and pushes forward directly on the throwout bearing to release the clutch.
      As noted in the post above, this system replaces the system of levers, pushrods and pivots that operates a mechanical linkage clutch.
        my buddy had a 79 ta with the 4spd. it felt like pushing 40 lbs with your leg everytime you hit the clutch.
        1996 Trans Am WS6
        A4, 3" VForce Catback, Corvette C6 rims, Slotted and Drilled Rotors, 160*stat, BMR SFC, HPP3, B&M Shift Kit.
          thanks guys .. appreciate the information.
