I've got a friend here who has an 87 TA with a small block chevy. Its got a holley 800 and an edelbrock rpm air gap manifold. Not too sure of the cam specs, but its not too wild. It has a normal HEI distributor with a new vacuum advance.
I dont know this carburetor stuff too well, so I'll throw this out to you guys.
Its having a problem with the timing advance. I think he set the basic timing at 8 degrees, but as soon as you give it some gas, the advance kicks in and you've got full advance by 2000-2500 RPM. What is making the advance kick in so soon? He knows the carb is too big, but I dont think thats the cause. Could the intake not be matched to the cam or something causing vacuum to go wild? I know its hard to answer that without cam specs, but is this a common thing? ANY help would be good. Thanks.
