3.73's or 4.10's?
  • 3.73's or 4.10's?
    Ok, eventually... not now by any means... I'm looking to beef up the gears in my ride. Just would like some opinions on which way to go.....
    Mind you, I am still new, and don't know jack about gears...so lengthy explanations are welcome
    1997 Trans Am WS6 Black M6
    370 RWHP / 352 TQ
    CC306 & Comp behives, LT1 Extreme Duty timing set, 1.6 RR's, CSR Elec Water Pump, Pacesetter LT's & ORY, GMMG w/ Ovals, K&N, Air Foil, TB Bypass, !AIR, !EGR, !CAGS, 160 deg thermo, LT4 KM, PCM tuning by Total-ReCal, March Pullies, Pro 5.0, 4.11 gears, LS1 alum DS, BMR strut tower brace, UMI SFC's, LCA's w/relo brackets & panhard
    You have an M6 I see. Get the 4.10's, that's the best gear for your trans.
    After the install, you will have to have your speedo. recalibrated.
      4.10's......you will have a totally different car.....much quicker off the mark.....the best mod I did.....
      DWS
      Silver M6 '95 Formula-sold to MCKNBRD
      Zaino all the way!!
      '03 Z06....Donaldson Blackwing, CAGS, '04 Z06 shocks, ceramic pads
        How much do you think I am looking at ($$$) ... from the gears to the install ?
        Also, how is driving "normally" with that kind of ratio?
        370 RWHP / 352 TQ
          You are looking at like 250 for the gears and install kit, and a few hundred for installation. My shop quoted me like 700 for parts and labor I think? Or maybe it was 500. I'm not quite sure, but either way I decided I wasn't going to pay it.
          I got a dial indicater and the other specialty tool you need and learned how to use it. Now I just need to buy the gear.
          My friend with 4.10's says they're awesome, and speed snaps a lot quicker, it just seems like he is constantly shifting. Makes 6th gear worth something too
            Got my 4.10's, now im just for a day thats not in the mid 90's.
            No time to be under a car.
              a quick check of tbyrne shows
              gears: ~$230
              gears install kit: ~115
              rearend girdle/stud kit: ~175
              installation: guessing $150-$200, depending on who you use......ask around for the best gear guy in your area......a sloppy installation you do not want....
              as far as normal driving, you will notice the higher gears are comfortable at lower speeds.....40-45 mph in 5th is not unusual.....6th is more usable, and not just an overdrive
              when you want to play, there is where the smile factor comes in.......and the gas gauge literally changes before your eyes
              DWS
              Zaino all the way!!
                I gave $330 for motive performance 4.10 (orange box) including master install with all bearings plus the crush sleeve eliminator spacer and shipping.
                I even had it on the porch the next day.
                http://www.gearsareus.com/
                Very helpful people as well, call em' up.
                You cqn get standard motive (blue box) for about $30.00 less.
                  find a rear end shop locally, let them order all your parts. i paid 380 for everything installed. for 373's.
                  1994 firebird formula
                    How much time would be shaven off your 0-60 and quarter mile times with a swap to 4.10's on an M6?
                    SOLD- Kinda miss it
                    SOLD- Good riddance!
                      I dont have them in yet, I have heard 2-3 tenths with a noticable SOTP improvement.
