Not sure if this will become a problem, but I recently turned on the headlights and only the passenger headlight went up (driver side stayed down). I turned them off, and when I turned them back on again, they BOTH went up (as they should). Anyone experience this before? Thanks.
Headlight problem?
Yeah its happens, sounds like the gear inside the motor is stripped. You can flip the nylon gear to the fresh side for a quick fix. Heres a link to a useful thread.
click
i think it's pretty common the motors on the ta headlights to go out.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
yeah been there... easy fix thoughOriginally posted by raroZ28i think it's pretty common the motors on the ta headlights to go out.
