I'm trying wiring up and electic choke to a car that originally didn't have one. Any idea where to hook it up? The carb is an edelbrock 600 cfm with electic choke. Where do these leads connect? Thanks.
Electric Choke
I put one on my '79 Camaro that originaly had the exhuast chock. Its been a while but I think I just used the accesory circuit. So as long as the ignition is on the chock will be hot or open.
I bought an Edelbrock carberator and there was no chock that I could tell. I did have a butterfly I believe so it must be internal.
The chock arm or the chock wire?
If the wire is disconnected you will get a rich mixture even when warm.
As I remeber I think there was a wire that was not connected to any thing and I just connected ht elec. chock to it. It turned out to be an accessory wire.
Originally posted by robschrI'm trying wiring up and electic choke to a car that originally didn't have one. Any idea where to hook it up? The carb is an edelbrock 600 cfm with electic choke. Where do these leads connect? Thanks.
Failing to hook it up will result in the car running like absolute crap. The choke coil will not heat up as it is supposed to and it will fail to release the choke. The car will run choked well after the choke should of released.
Start your lawn mower, wait till it is fully warm and pull the choke, see what happens. It might just die. In any event, it will not like it.Tracy
