dose any one know how much it would cost to get heads, intake and cam instaled and wich type is best lt4 con. which clames 425 which would be a 150 hp and thats with out headers or tb so if some one could help
thanx jon
1995 formula firebird
mods k&n fipk ,flowmaster catback, 52mm throttle body, crane hi-6 with lx92 coil,mad dog tranny with trans cooler
Putting the LT4 conversion on a stock LT1 will not give you 425HP. That claim is based on an engine dyno test done by More Performance at least 3 or 4 years ago. They got 429flywheel HP.
But it was not a "stock" engine in the sense that it had Hooker LT headers, a larger than stock throttle body (52MM?) and was tuned using a $3,000+ aftermarket engine management computer. I suspect there were a few other changes that More forgot to mention.
You can probably be looking at something in the 400+HP range with the LT4 conversion. Good headers would make a big difference. Then you need the larger TB and some very good tuning. And, to make use of a slightly "peaky" HOT cam, you are looking at maybe some 4.10 gears for an M6 or 3.73's and a 2,800 stall convertor for an A4.
At least 1/2 the people will tell you that you could get your stock LT1 heads ported to flow more than the stock LT4 heads, get a slightly more aggressive cam than the LT4 HOT cam, and make even more HP for the same, or even less $$$$. That is true, if you can find a reliable head porter, and IF you have the knowledge to pick the right parts. The LT4 conversion kit puts everything in a neat package and make life easier.
The LT4 kit is about $2,300. Add another $1,000 for coated LT headers/y-pipe, and a throttle body. I would guess that install and tuning could run another $1,000. So you are looking at $4,000-4,500 plus the drivetrain upgrades.
