Need help! Oxygen sensor!
  • Need help! Oxygen sensor!
    Ok. Here's the problem, I cant get the oxygen sensor from the passenger side header to come loose. Any sugestions at all? Because I really need to get it out of there and I'm sure some of you guys on the board have done it before. ANY help is appreciated!!! Thank you much in advance.
    96 Camaro Z28, T-tops, 6 Speed, Slp CIA, Flowmaster cat-back, 3:42 gears
    If you're talking about the O2 on the stock manifold, I couldn't get it out either. There's no room or access there. I know there have been a few to get them out, though...but I couldn't I tried using an O2 socket (open slit on 1 side to go over the wires) but I still couldn't break it loose. If you have headers, I'm sure they have better access, depending on the brand
    I know my SLPs are much easier to get to compared to the stock manifolds.
      No...their stock headers
        Not the same since I have JBA headers but maybe this might help.... use the PB Penetrant... I mean soak it ... for like a day or two. someone here told me about it and it works well.. Also go to Sears and look for the crowfoot tool. I used that to get to the hard to reach O2 sensors.
        97 TA, M6, JBA ceramic coated headers, Borla Cat-back exhaust, 1.6 RR, 160 Thermo, LT4 knock sensor, CAI, Bils, Hotchkis all around, GT rotors, B&M shifter, Magnecor wires, Granatelli MAF
        In the shop LT4 Intake and heads.
          The helms manuals state that they are very difficult to take off if their temperature is below 120* . Try heating them up, but not too they'll burn you and give it a try.
          pics and info
            Yes often times o2 sensors need to be heated.....usually with an oxy acetylene torch. You can try a small MAP torch, but it may not be enough. You want to heat the manifold AROUND the sensor, not the sensor itself. The idea is to get the metal around the sensor to expand as it is heated, making it easier to get out.
            Now, when (notice I say WHEN and not IF )the threads strip out in the manifold, dont worry too much. If you go to autozone (or any of them) you can buy a double sided spark plug hole tap (with 2 sizes). THe larger side is the same as the O2 bung. Double check the threads against the new o2 sensor and use it to clean up the threads.
              I already tryed pb, but i couldnt get it to spray where i wanted it so that ended up a mess. And I tryed running the car for a very little time and that didnt help. I have no idea what to do.
                Torch it. (the nut not the car)
                  get the little straw off a WD40 can .. or get some small hose and spray it into it and direct it that way ....
                    Spark plug arrestors from Autozone. They are intended to space the spark plug out from the head to prevent a misfire or something redneck, but they are also the same thread as an O2 bung, but at 1/3-1/4 the price. Go to an exhaust shop, have them torch a hole in your pipes and weld the arrestors in place. Leave your stock ones where they are (I couldn't get mine out either) and put the new ones in the new "bungs". Problem solved.
                      If youre going to an exhaust shop, just have them heat the crap out of it. Ive never had one that I couldnt get out with enough heat. Yes, the threads come with it, but you just tap it back out again like I mentioned earlier. Take it from a rust belt champion torcher......THere are some things you just NEED a oxy/acetylene torch for.......
