my dad needs some serious help
  • my dad needs some serious help
    2002 trailblazer with the 4.3 vortec
    Key is stuck in auxilary. Can start car and turn off key wont come off but car will stay in a type of auxilary mode with jsut the battery light lit up. Tried turning wheel either way doesnt make a difference. Anyone have any idea as to what is wrong?
    1995 LT1 bird
    10" 2800 stall coan converter,beefed tranny, supreme shift,motive 373 gears,3 inch catback with a flowmaster muffler, pcmforless tuned,slp cold air intake,tb bypassed, better flowing intake elbow, air foil,poly trans mount.
    275/40/17 Nitto NT555R extreme drags in rear
    2005 Dode SRT-4
    agp billet adjustable wastegate,Maxxfab 3 inch catless downpipe, borla catback ,K&N drop in filter,mapclamped,tuned,mopar blow off valve, Prothane motor mount inserts,21 pounds of boost!
    6 dics cd changer, 10 inch MTX fully loaded with moonroof and viper style seats
    is it in park?
    Greg W. in West Michigan
    1983 Z28-Parts car- *Sold*
    1984 Z28-305 HO Auto *Sold*
    1986 Camaro-V-6 5Spd *Sold*
    1984 Camaro-V-6 Auto *Sold*
    <Motor out
      im being serious man. i am stuck on this.
      1995 LT1 bird
      2005 Dode SRT-4
        I had a similar experience with my Camaro. One day the key just would not turn at all. The ignition cylinder just locked up. Unfortunately I had to get it replaced. It cost be roughly $175 Canadian, if I remember right. So hopefully it won't cost too much if this is the case with your dad's cylinder. My advice...get a good mechanic to take a look at it. Good luck, broh.
          Without closer evaluation, it could be a few things. One is what Todd said. That is most likely the case if you can't pull the key out under reverse, drive, neutral, etc. If you can, then it's likely misaligned.
          Misalignment: The adjustment of the park-lock cable to the ignition switch. Here's a fix for the f-body, but I'm not sure if this could be used for your application. http://shbox.com/trans/park_lock.html (Thanks to Shoebox).
          Another case I could think of is the park-lock cable came out of the ignition. On the 4th gen, the ignition switch is located on the actual steering column. When I pulled the column, the cable came out of the switch, so I wasn't able to pull the key out in park.
            ya it wont pulll out in any gear
            1995 LT1 bird
            2005 Dode SRT-4
              My Wife's Explorer had the same problem a few months back. Not that I would recommend doing this, but I was so aggrevated with the whole truck at that point, I just punched the top of the steering column, right above the cylinder. I pulled the wheel to the left and right one more time and finally heard a click. The key pulled out easily.
              It was most likely, as both Todd and Craig stated, a misaligned cylinder.
