Does anybody know the Delco part number for the 1 quart oil filter for LT1's? I thought it was PF1218, but when I picked one up from the parts store it looked smaller and shorter than I remember.
AC Delco Oil Filter part number???
You are correct. They changed the size, but kept the same part number. I was confused too when I bought it. When you look internally, it looks slightly different too. I've been using it for a couple weeks without a problem though.94 Black T/A GT, Advanced Induction 355, 3200 stall, built 4L60E, Moser 9", Baer Brakes, Shooting for 11s...
Could always go with a K&N oil filterSteve
87 GN - its just a 6... Mods
The stock filter is the PF25 for the small block and then there is the PF35 wich I use for my Formula that is used on the old big block trucks. It holds a least a quart of oil. The stock ones are just way too small. Use the PF35L or equivelant now. You'll get more filtering capacity.
As far as I know, the PF25, PF35 and PF35L have been discontinued for some time. They are still available from many sources thuogh, at least until the supply runs out. The larger PF35 was equivalent to the PF1218, and the synthetic media PF35L to the UPF1218. I used the UPF1218 for a while, but then that too was discontinued.
Currently using the Moroso 22460:
http://moroso.com/catalog/categorydi...?catcode=20002Fred
Originally posted by Dan B. 96 T/AFred,
It doesn't list pricing, or a dealer near Chicago, IL 60634.
Another alternative not mentioned above would be the Mobil 1 filter.Fred
Originally posted by Cerwin Vega FanYep I think my Mobil 1 filter is a 111 or 101.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
