ok was driving to work this morning when i blew a heater hose fitting at the check valve connector, coolant everywhere smoke everywhere not a nice site... well i got it towed, got some new heater hoses filled up with coolant and and bled system seemed ok, but when i took it out for a drive, the air fuel meter was pinged at full rich even at 1500rpm! the motor and car shake and there is a serious loss of power probably around 50% i have no idea what this can be minus replacing every sensor... im pretty sure its a fuel issue but im also keeping in mind the optispark which i just did a year ago... now if it was an optispark why would it run totally rich!? im guessing its a fouled sesnor somewhere but where minus replacing them all! i doubt its a headgasket becuase i didnt see any water in the tailpipe and no fluctuating temp after i filled the cooling system... also when i pulled over this morning to shut the car off i noticed the temp around 250ish and there were no idiot lights going off either which really boggles me... any suggestions would greatly be appreciated!
-chris
-chris
