Can someone please answer this question thats been bugging me... If i try do a burn out, or simply set off quickly the rhs tyre, passenger side looses traction and leaves a nice rubber trail and clouds of rubber smoke, the lhs drivers rear grips though, and is near impossible to make smoke, how come? how can i do burn outs like big tow??!!!
Wheel spinning and burn outs
Screaming Mad
Car: 1994 Camaro, 3.4l V6
Pace Setter headers & Y pipe, Flowmaster Z28 exhaust, K&N cone filter. modded 4l60e, trans cooler, strut brace, Eibach pro-kit
0-60 7.74
1/4 16.52 @ 85.3
Bike: Suzuki GSXR K4 600, K&N filter,Rizla kit, R&G bobbins, Db screen, LED indicatorsTags: None
You don't have a limited slip rear end.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
does the z28?Originally posted by Jeff 95 Z28You don't have a limited slip rear end.
Screaming Mad
0-60 7.74
1/4 16.52 @ 85.3
Oh yes.Originally posted by Screaming maddoes the z28?
2 words, line lock.
your welcome
PCM for Less tuned PCM, LT4 heads & intake, SLP headers, 1.6 RR's, SLP strut tower brace, air foil, throttle body bypass, oil cooler, 160* thermo, 3200 stall converter, manual fan switch, line lock, tranny cooler, exhaust cut outs, zexel torsion carrier w/3:73 gears, Magnaflow exhaust, Q-Logic Custom Dual 12" Sub Box, custom drk metallic blue decals, etc
www.WS6Racing.com
Line lock won't help without the limited slip rear end. You'll just burn one tire longer.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
go to local boneyard, grab a rear off of a 93-97 v8 bird or maro. swap out urs and installed newly purchased rear, advantages: better gearing(possibly), disk brakes, LSD. problem solved2009 Honda Civic EX- the daily beater
i know they dont work w/o limited slip. but every car with it shouldve come from the factory with a line lock. i love mine. so much i just replaced my rear end.
www.WS6Racing.com
I live in uk, so rear end is not gonna be cheap! but there are a few junk yards here with fbodys in them! only prob i can see is i would have to replace master cylinder and emergancy brake parts??
Screaming Mad
0-60 7.74
1/4 16.52 @ 85.3
summit racing
get richard at alders autos to order you a lsd unit from summit then get a tyre account as they dont last longhttp://www.pontiacdriversclub.co.uk/ keeping it pontiac in the the uk. 93 formula a4 ZR1 rims
mirror burn out movie top ten burn outs
how do i work out what gearing to use on the diff, not forgetting my maro is just a baby (v6)
Screaming Mad
0-60 7.74
1/4 16.52 @ 85.3
