After the MAF,IAT,IAC and Throttle body cleaning, gas air & oil filters, spark plugs replacement, I got a DTC P0300 (XXI century....it could be more specific, for Christ's sake!!!). Stumble/hesitation presented after 20 minutes (closed loop) after the engine was started, never in cold start or open loop. The scan tool signed the cylinder number 4.
Electric system check was performed (I mean: spark plug exchanged with the "neighbours", wire, injector IAT IAC MAF's harnesses, even a PCM OEM reprogrammed to stock). The fuel pump delivers 42 lbs yet!!!. Same culprit...cylinder #4
So, the poor fuel injector clogged, too dirty or damaged was the culprit by exclusion......as always...
My questions are: Should I replace the 24 Lbs fuel injector stock alone or since the engine is 56K miles old, Should I replace the whole set?..Now, I found a Delphi/Lucas 28lbs set a very good price ($199 vs $128 ONE!! OEM fuel injector !!!...this world is crazy..indeed).
Could a 28 LB fuel injector be installed in my stock fuel pump and engine without a problem? Will the miles per galon rate increase?
I would appreciate your point of view
Thanks
Dochidalgo
Thanks
Dochidalgo
