Steve and I tested a short WOT run with the stock tune...reading the fuel pressure, scanning it, and trying a Delco plug in there.
The fuel pressure showed no loss. It was high, steady and well at WOT...around 48 psi, exactly the pressure with the vacuum line off the FPR at idle.
The NGK plug, previously cleaned, turned a bit white, but not as white as before. I'm thinking it's because it was only a sprint to 50. The Delco plug has white spots, and wasn't as white as the NGK. But it still showed hot, in my opinion.
And after quickly viewing my scan, one thing popped up. At 5500-5800 RPM, the MAF reading showed 280 to 282. That seems awfully high considering it should be around 240
Does this mean anything?
Could this have anything to do with rocker adjustment?
Thanks again for your guys' help.
Does this mean anything?Could this have anything to do with rocker adjustment?
