i was driving around and all the sudden my i can change the gears to all of gears even to R do you guys know whats going on? then i turned my car off and is so easy to put in gear 1st 2nd and all the gear , then i turn my car on again and i can not put in any gear.
needed help real bad
2001 Trans Am WS6 M6
Tags: None
It sounds like the clutch is not releasing for some reason. Have you checked your clutch fluid level?2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
i haven't check anything yet bro i might do it tomorrow2001 Trans Am WS6 M6
