Hey everyone! I really need your help because I'm stumped - I just can't figue this one out! My Z28 has got a rough idle and the engine misses while accelerating. It's got about 130K miles. In the last couple of months, I've replaced the wires, plugs, opti cap & rotor. Then, when the problem started last week, I replaced the coil and ignition control module but no improvement. The head gasket is fine and there isn't a intake manifold leak - I changed the oil and everything looks normal. I got a solid Service Engine Soon light for a couple of minutes this morning but it went away after driving for a while. I took it to Autozone for a scan and they told me that the codes show a "random miss" and a rear O2 sensor is bad but they don't know if it's the one before the cat or after the cat.
I'm lost on this one!
Would an O2 sensor cause symptoms as severe as this?
What else do you think it is?? Thanks for your help!
Would an O2 sensor cause symptoms as severe as this? What else do you think it is?? Thanks for your help!
