Replacement foglights
  • Replacement foglights
    Do you guys know where I can get a replacement lens for the fog lamps on a '95 TA? I need the whole lens not just the bulb as the lens is cracked.
    Any ideas?
    13.685@102.11
    Hmmm...my only suggestions would probably be the obvious....GMParts Direct, classic industries, dealership. My only other suggestion, is if you can, try and find one at a junk yard.
      The parts list shows the lens but it leaves off the part number. It notes that it is part of the assembly for the whole lamp the part number for the lamp and the price from http://www.gmpartsdirect.com are listed below.
      GM PART # 16514251
      CATEGORY: Parking Turn Signal Lamp
      PACK QTY: 1 CORE CHARGE: $0.00
      GM LIST: $137.08
      OUR PRICE: $82.25
      DESCRIPTION: LAMP ASM-
      You could check here for a used one.
      http://www.billygrahamscamaro.com
        Is there an aftermarket foglight that can be used to avoid the ridiculous cost of the lens from GM that is similar shape that uses the same bulb?
        13.685@102.11
          I know a couple people go with a PIAA fog light that is almost identical to ours. PIAA can be expensive, so I'm not real sure if it's any cheaper than factory, but it will be a bit brighter. I'll try to find a part number for you.
