broke tranny gear
  • broke tranny gear
    95 3.4L 5 speed tranny, main shaft gear broke some pins, i was wondering what is the tranny model name number so i can try to look for it, as well as other vehicles with similar transmissions, like a 2WD jimmy or blazer in case i dont find a camaro tarnny in the area, i know the ratios might be diff, but i might not have much of a choice.
    It's a T-5 for a 4th gen V6. I happen to have one sitting in storage that needs second gear syncros. You could rob the good parts from it, or build one good tranny out of the two.
      http://www.tacreationsusa.com/manual.htm
      They list the 93-95 and the 96-99 separately. I don't know if there is a difference except for the price.
      Oh you can put 1st, 2nd, and 3rd gear synchro in a T5 very easily. 4Th gear requires a press to remove the gear.
      Synchros are about $20 each.
        would somone know what year make model blazers might have had a T5 or some very similar transmission?
          can i install a 89-92 V6 T5 in it?? cuz i think i found one...
            seriously would the 89-92 fit? how much diff in the drive ratios am i gonna experience? more low end or top end? or would each gear differ, i tried searching the net forever to find the gear ratios n just cant find it.
            i dont think ill find anything close other then this 90 T5 tranny. the inline shaft is whats broken so i cant realy rig it i dont think.
