Used to use Mobil 1 but they leaked the most, switched to K&N last summer and it worked until this weekend. Everything above the Oil Filter mount is dry and the Nut which attaches the housing to the block is torqued to specs so what gives? Oil is leaking between the aluminum mount and the rubber gasket which is attached to the Oil Filter. Guess all I would need is a hairline fracture but the structure is bone dry, oil is simply seeping out. The flat surface which the Filter screws onto also seems to be perfect, but once the filter is installed it's obvisouly no longer visable.
Any ideas because this is causing quite a mess, tranny gets covered with a nice layer of oil. This really should not be happening. When my motor was rebuilt a high volume oil pump (Oil pressure is good) replaced the factory unit but that shouldn't be a factor, right?
Thanks,
Eric 1997 Camaro LT4 SS #093
Thanks,
if you have already tryed all this than sorry for wasting your time just trying to help
Then just drop the 2 bolts holding the filter adapter in place. Easy 30 minute or less job.
Picked up Part # 88893990 from the dealer today but the New O-ring is round and black, not flat and orange like the gasket which I found mated to the block. The second New gasket is round and has two holes on either side with the middle being open, but this gasket wasn't even present when I removed my oil filter adapter?
