No Start Problem.. Mabey Fuseable links?
  • No Start Problem.. Mabey Fuseable links?
    Hey Everyone,
    My car is acting rather strange. The car was running fine yesterday. I turned it off for 2 minutes to open a gate and then when I tried to start it again, nothing. No gauge lights, no warning tone, no start, etc. However, I did hear a click/snap sound the first time I turned the key. Immediately I was thinking fuseable links. So I put a tarp over it (windows were down) and decided to look at it tomorrow(today).
    Today I tried to turn the headlights on to make sure it was a fuseable link. The headlights didnt turn on, which confused me because I thought that they were on seperate fuseable links. I waited a couple minutes and tried to turn the lights on again... This time they turned on! And now the ignition works again too! The problem fixed itself. I am worried about driving it because it may die on me again. Any ideas what would cause a problem like this? Is there another fuseable link that controls everything. It has also been very damp & rainy here. I am wondering if the moisture has something to do with it.
    No F-Body right now
    I once had a battery blow up in my Jeep. Put a volt meter on the battery to rule it out. I dont know much about the fuable links.
      Probably a poor connection to the battery.
        I would check the battery terminal connections as well as the connections at the starter, alternator and the grounds. Most likely it is a loose connection somewhere. If a fuseable link blows, it's not coming back to life.
          where are the fusable links anyway, you mean they are not repairable.
            On my 3rd gen, I have 2 fuseable links coming off the starter & a couple coming off the power distribution block near the battery. You cant repair them, but you can replace them. You can buy a new fuseable link for $3-4 or so at AutoZone, NAPA, Pepboys, etc.
            No F-Body right now
